15 years agoSGDMA data transfer question.
Hi, I did a memory transfer test from RAM to SDRAM using SGDMA, the speed test was evaluated using performance counter core, and it shows the transfer rate goes up to 370 MB/s with all con...
13 years ago --- Quote Start --- With a long sequential DMA transfer you should be able to hit 400MB/s at 100MHz on a 32-bit local interface. --- Quote End --- Hi BadOmen, Will I get this throughput if I am doing a transfer from BRAM to BRAM. Once my application is ready, I will be replacing one of the BRAM with DDR memory. Hi Micheal, are you HAL APIs for SGDMA transfer from RAM to SDRAM? The numbers are very good. Regards
