15 years agoSGDMA data transfer question.
Hi, I did a memory transfer test from RAM to SDRAM using SGDMA, the speed test was evaluated using performance counter core, and it shows the transfer rate goes up to 370 MB/s with all con...
15 years ago --- Quote Start --- This kind of speed is possible with SDRAM if you are using bursts or consecutive accesses, which is usually the case when transferring from a DMA. If you had random transfers, then asynchronous SRAM could become faster than SDRAM in some cases. --- Quote End --- By random transfer, you mean when data is accessed one at a time (non-burst) ? Michael
