18 years agosetup violation problem
Hello, I have a problem related to timing setup violation, my device is EP2C20F484C7, and I use classic timing analyzer as timing analysis tool. In addition, I use one global clock running at...
18 years ago --- Quote Start --- I'm not an expert but I have some ideas (in no order of significance): 1. Use clock enables instead of counter clocks (preferably in a process to avoid gated clocks) 2. You could try using a pll to generate the lower clock 3. I think you can assign the counter signal as an global signal to help the router do it's job Best Regards, Ola Bångdahl --- Quote End --- Thank you for your suggestions, I will look into my code and try to optimize my design.
