15 years agoSetup Hold times for Cyclone IV Flops
Hi All, I have looked in Cyclone IV Handbook and did not find T'su or T'hold for the flops. Is this info available somewhere? Can I safely assume t'hold to be zero? I am also trying to ...
15 years agoHello Rysc, thanks for the reply.
Ref: (are you asynchronously sampling data, and just trying to get an idea of how often it will go metastable? that's the only thing i can think of where these might be important) No, actually I am trying to Mux two data streams at 1x clock rate to a single stream at 2x clock rate. Both 1x and 2x clocks are phase (pos edge) aligned. Data is launched and latched by flops on respective domains. I have an internally generated enable signal, which basically toggles on every pos edge of 2x clock. I use it to capture/mux the 1st and 2nd stream. My concern is that the instance I am capturing the 2nd stream, at the same time (plus the Tco + Tpropagation delay from Source flop) the output of 2nd stream would be changing too. So my hold time at the latching flop would be Tco + T propagation delay – any positive clock skew on clk2x. Higher this positive skew, lower available hold time. Is this something which the tool can handle itself, or using a particular constraint would be recommended for a case like this?
