13 years agoSet-up and hold time of ALTDDIO megafunction module
I am using the ALTDDIO megafunction in an Arria V device to capture incoming data of the order of 1Gbps and my timing simulation (using Time Quest Analyser) tells me that delays should be so adjusted...
13 years agoSetup and hold requirements are essentially the same for all core registers, not only DDIO. I don't see a particular core register timing specification with the Arria V handbooks I checked (there may be newer revisions). But the requirement is reflected in the sample window specification for LVDS IO and discussed in the respective handbook parts.
