13 years agoset_false_path -from {ModA:ModA_inst|reg_src[144..244]} -to {ModB:ModB_inst|*} ?
I have a 2048 bit register that has a range of signals that need to be part of a false path. Instead of creating 100 lines like this: set_false_path -from {ModA:ModA_inst|reg_src[144]} -to...
13 years ago --- Quote Start --- It does create a list, but {} stops the interpretation of $i into an index, so the call fails ... --- Quote End --- So where are these things documented? I wouldn't mind studying hundreds of pages in order to understand all this but the documentation I have so far found is either not covering the relevant details or is so fragmented that is is essentially useless. The Timequest handbook essentially documents the supported SDC commands but there's nothing mentioned about TCL which one apparently is just supposed to know... As mentioned, I have a couple of books. One is just a summary and the other one is so thick i have not yet figured out whether it covers what I need. The "thick book" starts out by declaring that TCL is so great because one can create a web server using it :rolleyes: It got hard to read from there on...
