13 years agoset_false_path -from {ModA:ModA_inst|reg_src[144..244]} -to {ModB:ModB_inst|*} ?
I have a 2048 bit register that has a range of signals that need to be part of a false path. Instead of creating 100 lines like this: set_false_path -from {ModA:ModA_inst|reg_src[144]} -to...
13 years agoTcl will not interpret stuff inside {} ... try
set_false_path -from CommandRegisters:CommandRegisters_inst|reg_command_bits -to {MetaDataGenerator:MetaDataGenerator_inst|*}
and if that does not work
set_false_path -from "CommandRegisters:CommandRegisters_inst|reg_command_bits" -to {MetaDataGenerator:MetaDataGenerator_inst|*}
Tcl treats things inside {} as a list, except when it doesn't, eg., ${i} demarks the variable and is typically used in the case where it is ambiguous, eg. $ihatetcl is ambiguous, so it needs to be ${i}hatetcl. Tcl also treats [] as a request to execute a procedure, so in the string version above, you may need to use \[ and \] to stop Tcl interpreting the brackets. Cheers, Dave
