13 years agoSerial Flash Loader w/ Micron N25Qxxx Serial NOR Flash
Application Note AN-370-3.2, Using the Serial FlashLoader with the Quartus II Software, talks about programming the EPCS(Q) SPI devices with the JTAG cable and a bridge design in the FPGA. This allo...
10 years agoIf you want use N25Q256A/MT25Q512ABB in QUAD mode with ALTERA SERIAL FLASH CONTROLLER IP, EXTENDED QUAD INPUT FAST PROGRAM(12h) command is not supported, you can not program the device by this IP in QUAD mode, but STANDARD mode is compatible with EPCQ256.
Here is the differences between EPCQs and other options. -------------------------------------------------------------------------------------------------- EXTENDED QUAD INPUT FAST PROGRAM required cmd-address-data => 1bit-4bit-4bit -------------------------------------------------------------------------------------------------
Command Set
EPCQ256 N25Q256A83 N25Q256A13 MT25Q512ABB
9E/9Fh 9E/9Fh 9E/9Fh 9E/9Fh READ ID
06h 06h 06h 06h WRITE ENABLE
05h 05h 05h 05h READ STATUS REGISTER
0Bh 0Bh 0Bh 0Bh FAST READ
EBh EBh EBh EBh (X4)QUAD INPUT/OUTPUT FAST READ
02h 02h 02h 02h PAGE PROGRAM
12h 38h n/a 3Eh (X4)EXTENDED QUAD INPUT FAST PROGRAM
D8h D8h D8h D8h SECTOR ERASE
20h 20h 20h 20h 4KB SUBSECTOR ERASE
--------------------------------------------------------------------------- 12h/38h 4-BYTE PAGE PROGRAM command is NOT SUPPORTED by N25Q256A13EF840x, this one is used in stratix V GX demo board.
