13 years agoSerial Flash Loader w/ Micron N25Qxxx Serial NOR Flash
Application Note AN-370-3.2, Using the Serial FlashLoader with the Quartus II Software, talks about programming the EPCS(Q) SPI devices with the JTAG cable and a bridge design in the FPGA. This allo...
13 years agoSuccess!!!! Board boots custom bit file from Micron PROM. Actually used Active Serial x4 to speed up programming.
Did everything is Application Note AN-370. Was using the Stratix V GX evaluation board that has an A7 part and a Micron 256Mb SPI Serial Flash. Remember to COMPRESS the bit file. A7 bit file is larger than 256Mb (~1.48Mb larger). Can't wait for SW support for the 512Mb Flash.... Ignore the double attachment....Same pic.
