16 years agoSerial configuration problem of Cyclone II device using quatrus 9.1
I have a working design implemented in a Cyclone EP2C5T144C7 device conficgured by an EPCS1 prom in Active Serial mode. I switched to Quartus 9.1, recompiled the project, and reprogrammed the...
16 years agoThanks very much for the reply!
I have checked the "generate compressed bitstreams" box in the "device and Pin Options" Configuration tab. Is there some other palce I need to specify this as well? The odd thing is that all of the obvious device options seem to be the same the same as they were when I was using V9.0 SP2, which worked great. Mats
