18 years agoSequential code vs concurrent code
Hello everybody!! I have some doubts about PROCESS and FOR, i want to know how much time spends an instruction inside a process.Also i saw in simulations that instructions inside FOR runs in co...
18 years agoThe VHDL term sequential designates statements, that are interpreted by the compiler "in in the order in which they appear in the code. VHDL sequential statements can appear only in processes and subprograms." (From Synopsis VHDL Reference Manual). But the logic as a whole is executed fully parallel either permanently (asynchronous) or at a clock edge (sychronous).
The logic generated from sequential code must not necessarily depend on statement order. As Rysc mentioned, this is mainly the case when using variables, that can get multiple assignments (of different values) in a process or subprogram. But in any case, no sequence in time is implied, it's another way to create parallel logic. This could be different in VHDL simulation code, that can use delay instructions to achieve a sequence in time.
