13 years agoSeeking some advice and technical help regarding creation of multicore system
Hello all, I am trying to create a multicore system that I will use for JPEG encoding. I am using a DE2-115 board along with Quartus 12.1, Qsys and associated build tools for Eclipse. I have ...
13 years agoI can't help much but i can offer a point of view.
Running multiple Nios cores will still pale in comparison to having the compression in hardware HDL; by enormous differences. There is alot of overhead on running C instructions on a Nios. Having a multicore CPU setup could likely be as difficult or more so than converting your C code to verilog. If you do it in hardware you will use less resources and at the same time Can create more parallel processes that peform much quicker.
