15 years agoSDRAM used on Bemicro eval board
I am trying to test the new Bemicro eval board purchased from Arrow. (Note: this is the 2nd generation USB eval board that has temperature sensor on it). According to the schematic, the board has ...
15 years agoI just started fighting this problem too. Probably you have on older Bemicro version with CIII. I have a Bemicro-SDK with Cyclone IV that requires Quartus 10. But my problem is the same as yours- there is a useless overprotected example of Mobile DDR IP that does not work at all, and I am trying to use Altera's DDR SDRAM Controller from SOPC Buider. It looks like this is not an easy task and what I've got so far is:
"Warning: cpu_0: The address range of the slaves connected to the Nios II instruction masters exceeds 28 bits. Attempts to call functions across 28-bit boundaries is not supported by GCC and will result in linker errors. " IS this really possible?
