15 years agoSDRAM problem in SOPC builder.
Ok.. I realized i posted this in the wrong section of the forum(software), this is probably a hw question, so i repost it here. --------------------------------------------------------------------...
15 years agoHi Michael
--- Quote Start --- "Warning: cpu: The address range of the slaves connected to the NIOS 2 instruction master exceeds 28 bits. Attempts to call function across 28 bit boundary is not supported by GCC and will result in linker errors" --- Quote End --- This is because one of the slaves you connected to instruction master has been mapped to address 0x1000 0000 or above. Locking base address is the correct procedure. You must have: base_address + slave range < 0x1000 0000 Connection to instruction master is mandatory if your memory slave is supposed to store code, since Nios use this bus connection to fetch instructions into the cpu for execution. If you use a memory device uniquely for data storage, then only connection to data master is required. Separate instruction and data paths are convenient because cpu can fetch both an instruction and data in the same cycle, thus increasing performance compared to a single bus machine. Regards
