15 years agoSDI questions
in the sdi megecore what frenquency we supply to the gxb4_cal_clk in 3g mode 148.5? in hd mode 74.25 ?
i see the arria model the project supply 100mhz to the gxb4_cal_clk the user guide does not descrip it clearly so i need help thank you very much very hope for you apply ;)3 Replies
I have the same problem with the SDI megafunction when using the normal SD and HD modes. When choosing to triple standard the sample works with 148,5MHz, but it does not work with the other SDI megafunctions. Which frequency (gxb4_cal_clk) should I used for the megafunction?
Best regards - Altera_Forum
do it work? i find i can not lock video as you
if you find some useful informations pls tell me thanks bless my poor english - Altera_Forum
Hello
I use a 27MHz oscillator it is free running and is not locked to the video clock. BR,
