10 years agosdc files order
Hi guys, I have several sdc fiies, some from 3rd party vendors. 1. do i put my first (with the clock definitions).... MY.sdc Qip.1.sdc ... 2. or Qip.1.sdc .. MY.sdc ...
10 years agoone more is you may...
my sdc: create_clock -period 3.104 -name {clk322M} [get_ports clk322M] create_clock -period 10.0 -name {clk100M} [get_ports clk100M] create_clock -period 40.0 -name {clk25M} [get_ports clk25M] create_clock -period 10.0 -name {qdr2_refclk} [get_ports {qdr2_refclk}] derive_pll_clocks derive_clock_uncertainty if that called last is OK? or should i split it to one file with clocks at the beginning, then another with derive_pll_clocks at the end....?
