15 years agoSD card problem in NEEK
hi all,
i am new in altera tools and i use in my project NIOS || Embedded Evalution Kit (NEEK) here is the link for the kit for more details:http://www.altera.com/products/devkits/altera/kit-cyc3-embedded.html i wanna connect my sopc builder system with SDCard i.e. i wanna to read and write from SDCard on the second board : lcd_multimedia _Hsmc, SDCard can work in two modes which are 1-SPI mode 2-SD mode i will make SDCard to work in SPI mode so i am going to use SPI core in SOPC to connect SDCard with. After i make connection between SPI master on FPGA and SDCard on second board i try to write driver for SDCard using altera Apis for SPI Note:SDCard need chip select signal can be drived low. so i need more details about ss_n signal from SPI so as to use it to connect with SDCard "CS" if someone tried like this project please help me in this problem thanks in advance1 Reply
also when i try to write zero in slave select register and try to read it to make sure from that
i found it 1 IOWR_ALTERA_AVALON_SPI_SLAVE_SEL(sd_hardware->spi_controller_base,0); slave=(unsigned char)IORD_ALTERA_AVALON_SPI_SLAVE_SEL(sd_hardware->spi_controller_base); i found that slave =1 not 0 please help me in this problem thanks in advance
