18 years agosampled signal on falling or risins edge?
Hello, I have a beginner question. With the code below The signal in_width_pulse_n is wide of one period (clk_speed) My question is on signal old1_width_pulse_n I must be sampled it ...
18 years agoI can add that use the falling rising not make your margin safer, but force your design to go twice faster. It's as if you use a clock of double frequency and on a rising edge clock you generate the data and on the following one you acquire it.
I really suggest you to not change the sampling edge and let the compiler do its work.
