13 years ago"Safe" state machine
Hi, Attached herewith is the Altera safe_state example. I want to build my code around this kind of state machine (for robust design). My question is why didn't you used "when others" in your ...
13 years agoAn others case not representing existing states is meaningless, both in standard and safe encoded FSM. If I remember right, the empty others case has been required by previous VHDL versions.
one-hot will be the default encoding in most cases, thus it can be expected meaningless as well. The only drawback of safe enconding is a slight increase in LE usage, you can try yourself.
