13 years agorx_clkout - route to which output pin
I'm planning to use the ALT_GX module in an Arria II GX FPGA like indicated here: http://www.altera.com/literature/an/an610.pdf Page 7, figure 4. The question I have is which output pin sho...
13 years ago --- Quote Start --- what is the suggested pin type to use? --- Quote End --- I would recommend the PLL_OUT pin, along with whatever resistors are needed to make the pseudo-differential signal compatible with the TI clock chip. Since the signal is a clock, you can AC-couple, so you'll just need to check that the amplitude of the output does not exceed the input to the TI jitter cleaner. File a Service Request with TI and ask which pins they used, or recommend. Please post their response here, in case others have this same question. Cheers, Dave
