14 years agoRJ-45 Pins on Cyclone IV GX?
Hello, Can anyone tell me the name of RJ-45 pins on Cyclone IV GX? I need to connect them to my project, but I don't know their name. :oops:
14 years ago --- Quote Start --- I found them in the schematic, but I don't see them in Pin Planner. :confused: --- Quote End --- Pin planner will only show them if you have a design that uses them. I typically have a top-level entity with all ports defined and then use a Tcl script to assign pins. Using the GUI, I think you can elaborate the design (for Quartus to find out which pins you have used), and then you can use the Pin Planner to assign the pins per the schematic. Cheers, Dave
