18 years agoRis/fall time?
Hello, I am developing a simple test board for a cyclone FPGA (EP2C8T144). It is my very first FPGA project, and I want to build my own FPGA board. Now, my question is: Which rise and fall...
18 years agoDear OrchestraDirector,
thank you a lot! My ARM works with 72 MHz, but the external data bus is slower. So, I think this could work ;) Is it maybe possible to use longer tracks than 25 mm? And is it correct that only the Pins, which are outputs on the FPGA, need a series resistor? Thank you for your help!
