10 years agoRGMII Source Synchronous Timing Problem
Hi design: My design interfaces an RGMII Gigabit Ethernet running at 125 MHz with 4 bits of data and 1 bit for validity of data. Data & clock are edge-aligned at the PHY output ports: Da...
10 years agoHi msj. I use phy Marvell 88E1111-BAB-1000 (on my own board) and Micrel KSZ9021RL/RN (on Terasic Cyclone V kit). This chips has internal DLL for TX and RX path (to MAC). Micrel's DLL is cool and magic! You may set CLK to Data and Clk to CTL delay with 0.2 ns precision!
Register 260 (104h) - RGMII Clock and Control Pad Skew 260.11:8 rxdv_pad_skew RGMII RX_CTL PAD Skew Control (0.2ns/step) 0111 260.7:4 txc_pad_skew RGMII TXC PAD Skew Control (0.2ns/step) RW 0111 260.3:0 txen_pad_skew RGMII TX_CTL PAD Skew Control (0.2ns/step) RW 0111 Register 261 (105h) - RGMII RX Data Pad Skew 261.15:12 rxd3_pad_skew RGMII RXD3 PAD Skew Control (0.2ns/step) RW 0111 261.11:8 rxd2_pad_skew RGMII RXD2 PAD Skew Control (0.2ns/step) RW 0111 261.7:4 rxd1_pad_skew RGMII RXD1 PAD Skew Control (0.2ns/step) RW 0111 261.3:0 rxdO_pad_skew RGMII RXD0 PAD Skew Control (0.2ns/step) RW 0111 You may see Altera an477 about constraining RGMII. Try use LogicLock option. See Timequest. My project report:https://www.alteraforum.com/forum/attachment.php?attachmentid=11840 . Difference between lines must be <<1ns! (My project for Cyclone V and my own board)
