10 years agoReverse Timing analysis (from .pof file)
Hi, I'm working on a number of older systems which the original engineer somehow designed without using ANY timing constraints. These systems have been deployed for a number of years to several...
10 years ago --- Quote Start --- Which versions? Could you explain why? --- Quote End --- All versions from at least Q8 (and maybe earlier because I think Ive done some successful recompiles with max + plus2) through to the latest will produce the same results with Identical source code. The key point is identical - any change to any part of the source will produce different results.
