10 years agoReverse Timing analysis (from .pof file)
Hi, I'm working on a number of older systems which the original engineer somehow designed without using ANY timing constraints. These systems have been deployed for a number of years to several...
10 years agoEven if you compile with the same version, you timing will probably be different. I'd re-compile and add any constraints needed to close timing. Make sure you completely understand what the real world timing needs to be for any external interfaces.
