10 years agoreset sync design logic
I have a question regarding reset sync logic .
first of all what I understood about requirement of reset synchronization in design : - Reset will be asynchronous in nature. - It is not an issue if reset assertion in design will not be on active edge. - But when de-asserting reset at that time it must be on active edge of clock. - If de-assertion is asynchronous in nature then it may case design output to stuck into metastable-state - So to prevent it reset synchronize is used. ( I would request to all member to clarify me about need of reset synchronize if i understood something wrong !!! ) - When I google about how to design reset synchronize module I just confused with the way they have synchronize reset with clock. //================================================================================================================================== // reset synchronize logic snippet I found from website //================================================================================================================================== module reset_synchronize ( input clock_i, input resetn_i, output sync_resetn_o ); logic resetn_f1; logic resetn_f2; assign sync_resetn_o = resetn_f2; always_ff @(posedge clock_i or negedge resetn_i) begin if(~resetn_i) begin resetn_f1 <= 0; resetn_f2 <= 0; end else begin resetn_f1 <= 1'b1; resetn_f2 <= resetn_f1; end end endmodule //============================================================================================================== // what I observed from above snippet & my question //============================================================================================================== - have used two flip-flops ( no idea for what they have used second flip-flop as my reset will sync only need 1 flip-flop ) - when reset_n is there will be keeping "resetn_f1" & "resetn_f2" zero ( I am okey with this !! ) - when reset_n = 1 then will be giving "resetn_f1 == 1" & "resetn_f2 = resetn_f1" Q1 : whay they have used "resetn_f2" as with simple "resetn_f1" also I can have de-assertion of reset_n on clock edge.11 Replies
synchronising an async signal requires at least two stages of sampling. When you say it should be one register then you are not looking at the issue of edge violation but you are only thinking of sampling.
The first register will be violated from time to time but it is hoped that its Q output will settle before next register samples. However the second register may be violated (this is very low probabilty given by MTBF). Three stages will improve MTBF dramatically such that a failure may occur once every million years? just guessing but it should be that far. To synchronise an async signal there are two designs, type1 passes signal directly through D register of first stage (such as dc fifo pointers being passed from one clock domain to another while data itself is left in memory cell or register till pointer arrives then sampled). Type2 is the one you posted. It is used for reset (and is called reset synchroniser). The difference is that the async signal is not passed through D input of first stage but rather it is used as async reset for both stages and the first stage samples from constant logic '1'. This is believed to be more safe and the explanation given by various sources is vague but my thoughts are as follows: In type1 the second register may be unlucky and get violation if its first register did not settle within one clock period. In type2 imagine reset violated register1, its input is not changing (constant '1') but its output needs to change state and so will get violated. reset and clock then travel together to second register (before data arrives) and it does not change state as input is '0' and output is '0' and so will not be violated (but will be violated if data is too early-unlikely). on the next clock edge the first register will sample safely its constant input and so will the second register
