17 years agoreset MAX II
hi, i would like to know if i can rely on the power-on-reset of MAX II to know the initial values of the outputs? or should i use external reset? thanks sharen
17 years agoThis issue was discussed in heated recent threads.
In short, no it is unreliable but yes it is, provided you exercise some care. The power-up values themselves are reliable(provided you set its Don't care off) since async reset is applied soon after configuration phase. The problem is that it is released non-synchronised to clk(or clks) and hence may upset your design at startup. To overcome that generate your own internal reset(depending on powerup values being 0 e.g. a counter), then apply it as usual to async ports (after being synchronised to its clk)
