15 years agoReprogram Max II CPLD?
During development, test, and debug, etc...can I reprogram the Max II CPLD many times via JTAG? if yes, do I need to do anything to erase the old program first before the new program could be progra...
15 years agoThe device handbook specifies (only) 100 minimum erase and program cycles, so many times is relative. Typically, you can expect more, I never experienced an exhausted MAX II configuration flash. User flash endurance could be more problematic depending on the application. Sucessor MAX V has raised the user flash specification to 1000 cycles.
*.pof files should be selected for programming, erase will be done automatically without performing it separately.
