17 years agoremote upgrade EPCS config data
I am trying to download configuration data using rs232 and program it to EPCS. The data is downloaded and checksummed correctly, programmed to EPCS (starting at address 0) and read back correctly. B...
13 years agoI always read back the EPCS that I programmed with the .jic and the I also read it back when I have programmed it through .rbf/.rpd and compare that way you can tell what the problem is. At least you will find out if you have an endian problem or similar.
