10 years agoRegistering partition boundaries and reducing combinatorial logic
I have a module dac that is instantiated inside of module registers. The module instance dac drives pins dac_data_bus[11:0] at the top level. I am receiving TimeQuest recommendations to "register the partition boundaries for the path" and "reduce the levels of combinatorial logic."
As I understand it, reduction in the levels of combinatorial logic is to pipeline an operation. Both dac and registers are driven by the same clock. Is there a general design method that I can use to register partition boundaries and reduce combinatorial logic? What does this recommendation imply, and how do I fix it? Here is the TimeQuest output: Register the partition boundaries for the path from registers:registe...|dac_data_bus[0] (http://about<strong></strong>:blank#) to dac_data_bus[0] [hide details] (http://about<strong></strong>:blank#)- issue: cross-partition paths (rdb:cross-partition%20paths)
- to: dac_data_bus
- timequest analysis: }%20-to%20{dac_data_bus
- partitions that should be merged:
- hard_block:auto_generated_inst -> Top
- issue: long combinational path (rdb:long%20combinational%20path)
- to: dac_data_bus
- extra levels of combinational logic:
- 2
- to: dac_data_bus
- 2
