8 years agoReference clocks for Transceiver PLLs
Hi, I'm having issues with transceivers, which I have not used before. Currently I am trying to get a 1.25GHz clock from a Transceiver PLL. The clock I am trying to use as a reference clock is ...
8 years agoHi,
Okay, If you are facing the same issue compare with reference design OR the pin connection guidelines in below links. http://www.alterawiki.com/wiki/arria_10_transceiver_phy_design_examples https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/dp/arria-10/pcg-01017.pdf Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
