15 years agorecompile needed in project navigator
Hi all I have created a project through project navigator, set project options and added source files and finally generated the tcl script file to be able to run the flow through the command line....
15 years agoI'm using version 9.1, i notice also this issue, when i run analysis and synthesis only and then start fitter i find analysis and synthesis turned to yellow !!!
I will try different strategies to make sure it's not a problem with the project or a network delay as my home as remotly mounted. There is another point i should ask about, The machine with cores license has redhat while the strong one has ubuntu10.4. I want to know if changing OS's causes this problem thanks in advance
