15 years agorecompile needed in project navigator
Hi all I have created a project through project navigator, set project options and added source files and finally generated the tcl script file to be able to run the flow through the command line....
15 years agoNone replied !!! let me define the problem more
I have to run synthesis on a certain machine that has a license for encrypted source files but this machine is slow one, it's a dual core machine, the tool do not check the license in the fitting phase so i can run quartus_fit on another machine which has 4 cores. I then need to check for the license again in the assembly phase "quartus_asm" so i return back to the machine that has the license. When i finally open the project navigator and program the device through signal tab it tells me recompile the project to continue !!! it sees the project not compiled although i have successfully compiled it using terminal on two machines as i stated above How the project navigator updates the status of the project, to know if it has been compiled or not ? thanks in advance
