15 years agoReceiving LVDS using NIOS II
Hi , Does anyone have any experience in receiving LVDS signal using NIOS II?? I have no idea where to start from. Thanks in advance. Regards, Michael
15 years agoHi Dave,
I am trying to get the LVDS (output from an ADC running at maximum 65Msps, 14bits) signal using NIOS II processor, and display the information on the 8'' LCD (tPad from terasic), and also save data, by transmitting to computer using High Speed USB2.0 (QuickUSB from Bitwise). If the throughput of the LVDS data stream is 65Mbps(14 pins), can NIOS II handle this fast enough? I am assuming the NIOS II can handle maximum data throughput of 185Mbps per pin, since it could be clocked at maximum frequency of 185MHz, and also a 6 stages pipelined processor. Is this assumption correct? Please advice. Thank you. Regards, Michael
