13 years agoReceiver to FPGA
Hi, My project goal is to connect a receiver of 15Mbps to computer through FPGA DE3/DE4. I want to ask which component should i connect my receiver? and if i need clk from the receiver as well? ...
13 years ago --- Quote Start --- At 15 Mbps you can also use a DPLL (running at 8x or 16x the bitrate) and get away with Cyclone devices (-6 speed grade perhaps for the x16 case) --- Quote End --- Right. With Cylone III and above, you can also implement a kind of soft CDR based on PLL dynamic phase shift capability, working at considerably higher data rates. I didn't mention Cyclone related solutions, because tzahi is explicitely asking for DE3/DE4 (Stratix based) dev kits.
