13 years agoReceiver to FPGA
Hi, My project goal is to connect a receiver of 15Mbps to computer through FPGA DE3/DE4. I want to ask which component should i connect my receiver? and if i need clk from the receiver as well? ...
13 years ago --- Quote Start --- How does the 15Mbps data arrive to you? (Ethernet? parallel bus? high-speed transceiver? other?) I would suggest you send your data over Ethernet to the computer unless there is a compelling reason not to. --- Quote End --- The data arrives by high speed serial receiver - image attached. https://www.alteraforum.com/forum/attachment.php?attachmentid=6574 Tnx, Tzahi
