13 years ago
Reading data from Flash
I use an Altera DE2-115 board.
I have written some data into my flash memory in the board using the control panel tool.
Now, I intend to read the data and process it by a logic to be implemented in QuartusII.
Suggest ways to read the data from the flash into the QuartusII project.
Nadeem
    You can use a NIOS processor to read data from this memory and make it available for any other module inside your project.
    --- Quote Start ---
    --- Quote End ---
    Thank you.
    I have a very basic question, pardon me for asking it.
    How do i connect the array in memory and the one i name in the program,does Nios automatically assign the variable name to that particular array that is being read?
    I'm not sure if you can do this in the BSP Editor, but you can try.
    You can check if it shows in the Linker tab the Flash Memory, if it's there you can have access to this part of the memory creating a variable/vector in this section (using .xxxx). It will probably work this way, but it'll be slow.
    I think the best way if you're going to use a NIOS processor is to transfer data from the FLASH memory to the SDRAM or Onchip Memory.
    --- Quote Start ---
    --- Quote End ---
    Would be glad if you can send me a NIOS project example as i haven't worked with NIOS before. Thank you
