14 years agoReading data from a ROM
I have created a ROM-1port via the MegaWizard which also has a .mif file and in my top level entity I have to instantiate that rom, but I don't know how to access the data from it. My .mif file...
13 years agoYour code below is a good attempt, however, you need something where you increment the address, then read:
--- Quote Start --- It's what I did, but I don't seem to get anything on the output... tried several different ways too. Here's the state machine:
port
-- 50MHz clock
clock : in std_logic;
reset : in std_logic;
ver : out std_logic_vector(15 downto 0)
component rom -- MegaWizard created rom
port
address : in std_logic_vector(4 downto 0);
q : out std_logic_vector(7 downto 0)
signal addr_rom : std_logic_vector(4 downto 0);
signal data_out_rom : std_logic_vector(7 downto 0);
type state is (addr0, addr1);
signal st : state;
rom_inst : rom
port map
address => addr_rom,
clock => clock,
q => data_out_rom
process(reset, clock)
begin
if reset = '1' then
st <= addr0;
elsif rising_edge(clock) then
case st is
when addr0 =>
addr_rom <= "00000";
ver(15 downto 8) <= data_out_rom;
st <= addr1;
when addr1 =>
addr_rom <= "00001";
ver(7 downto 0) <= data_out_rom;
st <= addr0;
when others =>
st <= addr0;
end case;
end if;
end process;
How can I be sure the .mif file was loaded? I don't know what is going wrong... James could you please post a code of what you meant? --- Quote End --- So something like this: process(all)
variable addr : natural range 0 to NUM_PARAMS;
begin
if HRST then
param1 <= (others => '0');
param2 <= (others => '0');
param3 <= (others => '0');
elsif rising_edge(MCLK) then
case state is
when S0 =>
if Update then
state <= S1;
else
state <= S0;
end if;
addr := 0;
when S1 => addr := addr + 1;
state <= S2;
when S2 => param1 <= coeffData; (This would come from your ROM that you instantiate)
state <= S3;
when S3 => addr := addr + 1;
state <= S4;
when S4 => param2 <= coeffData;
state <= S5;
when S5 => addr := addr + 1;
state <= S6;
when S6 => param3 <= coeffData;
and so on . . . . Best, James
