2021, this is still the case. Astonishing that they ship drivers that will simply not work for 99% of win10 users
The drivers in Quartus 20.1 are unsigned
I attach screenshot of what my Windows 10 says
Doesn't even complain about hash, just says no.
Had to turn off driver signing enforcement, then worked fine via JTag
Yep that's exactly the message I get.
Specifically how did you disable driver signing?
- Fancellu5 years ago
https://www.technipages.com/enable-disable-device-driver-signing
Option 2.When you install driver after that, it will warn you and ask if you are sure.
I even went and bought another USB Blaster, thinking that mine was faulty!
Thanks Intel!!!
- fdsa985 years ago
Did you try option 1?
I tried both. The first didn't seem to work though I'll try again. The second bricked my computer. If you have an encrypted drive you need the encryption key to use option 2. IT fixed it but I'm not doing it again.
