richwright
4 years agoRd, OCT Default Value in LVDS
I am using an Arria 10 GX device. There are a number of pins using LVDS IO standard. The Termination has been set in Pin Planner to Differential but the "Receiver On Chip Termination" has not been s...
- 4 years ago
Hi there
By checking on https://www.intel.com/content/www/us/en/programmable/documentation/sam1403483633377.html#sam1403482197912
The Rd OCT shall be of 100 ohm.
EngWei_O_Intel
4 years agoHi Rich
If you refer to
https://www.intel.com/content/www/us/en/programmable/documentation/nik1398707230472.html
parameter is meant for usage of transceiver.
For LVDS GPIO, you can do the setting through Assignment Editor, or manually using the INPUT_TERMINATION assignment as mentioned in
