Printer problem with Intel Quartus Prime Lite Edition 21.1
I had a similar issue when I installed Intel Quartus Prime Lite Edition 21.1 on my system. It was frustrating not being able to print directly from the program. However, I managed to find a workaround that might help you too:
Check Printer Settings: Ensure that your default printer is properly set up and selected in your Windows settings. Sometimes, programs can have trouble recognizing the default printer.
Printer Permissions: Make sure that Intel Quartus Prime Lite Edition has the necessary permissions to access your printer. You can do this by checking the program's settings or through your computer's security settings.
Update Printer Drivers: Ensure that your printer drivers are up to date. Outdated drivers can sometimes cause compatibility issues with certain programs.
Try a Different File Format: If you're still unable to print directly from Intel Quartus Prime Lite Edition, try saving the file as a PDF and then printing it from a PDF viewer like Adobe Acrobat Reader.
I hope these suggestions help you resolve the printing issue with Intel Quartus Prime Lite Edition. It can be frustrating when software doesn't cooperate, but with a bit of troubleshooting, hopefully, you'll be able to get it sorted out.
