PI_ERROR_DEVICE_NOT_AVAILABLE while executing/debugging FPGA_Compile example on EMULATOR
- 1 year ago
Hello, I was able to solve the problem,
Turns out setting the variable CL_CONTEXT_MPSIM_DEVICE_INTELFPGA causes problems with emulation and debugging. Unsetting this variable fixed my problem.
Hi @cagxel,
Just to add on the emulator would required specific version of GCC to work, which is 7.4.0 or later.
Hence please so check on the system/setting/environment variable. More details can be found in the link below:
Best Wishes
BB
Hello, thank you for your response. I been using GCC version 13.2.0, Quartus Prime and OneAPI version 24.2 with FPGA support package installed on Ubuntu 24.04.1 LTS when I was doing the steps I mentioned in my post. I didn't make any changes to the files on Github repository. Unfortunately my problem persists.
- cagxel1 year ago
I just ran the OneAPI diagnostic tool and I get the following error
Check name: dpcpp_compiler_sys_check Description: This check verifies if the environment is ready to use the Intel(R) oneAPI DPC++ Compiler. Result status: FAIL Intel(R) oneAPI DPC++ Compiler requires gcc version 5.1 or higher. Warning: INTEL_FPGA_ROOT is not set. Warning: Open Programmable Acceleration Engine (OPAE) driver was not found.However, my pc is using gcc version 13.2.0 and I couldn't find any information on forum or the oneAPI documentation regarding how to set INTEL_FPGA_ROOT. In addition to that there are bunch of "gcc4.8" directories inside oneAPI installation directory that is installed with basekit.
