Cyclone V PCIe HIP is stuck at L0 state and no activity on tl_cfg_ctl & tl_cfg_add
As suggested, I tried driving the npor with the pin_perstn signal but no change in the output.
Me and Harris had a second call after few mins again and here is the conclusion from the call.
Few pointers that we discussed in the second call after I tried the experiment quickly.
- The current reset status that we captured in the signal tap is correct. Since the signal is active high and not active low. So original output was correct.
- Since the design has already enumerated the it is out of reset.
- Reviewed the IP configuration and the Tool version with Harris.
- I have attached the ppt with design description and the signal tap file with all the signals captured value as requested by Harris
- Harris to review the files and the ppt and get back to us with nest steps.
- RichardT_altera4 years ago
As mentioned by Harris:
I checked the signals in .stp file, they were probed in post-fitting mode which was not correct way since signals might be no exist after full compilation. After I changed to pre-synthesis way, we can find PCIe HIP works well like ‘tl_cfg_xxx’ are toggling and ‘tx_st_ready’ is high. Currently, the problem is in user logic, why user logic doesn’t send out packets on AVST TX interface. Customer will need to debug the user logic next.
With that, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Richard Tan
