richwright's avatar
richwright
5 years ago
Rd, OCT Default Value in LVDS
I am using an Arria 10 GX device. There are a number of pins using LVDS IO standard. The Termination has been set in Pin Planner to Differential but the "Receiver On Chip Termination" has not been specified. I cannot find any documentation that tells me what the compiler does with the On Chip resistance, Rd, if the value is not specified. There three values to choose from 85 ohm, 100 ohm, and External Termination.
I can see that the GSF adds lines of code when this parameter is changed in Pin Planner:
set_instance_assignment -name XCVR_A10_RX_TERM_SEL R_R1 -to ICBS_1_P
set_instance_assignment -name XCVR_A10_RX_TERM_SEL R_R1 -to "ICBS_1_P(n)"
I have not seen much noticeable change in signal at this receiver when I change this value. Perhaps the default is what I am setting.
Can anyone tell me what is the default value and show me where that is documented?
Is there any possibility that something , like a Global parameter or anything else, that can override the Receiver On Chip Termination (Rd)?
Note: I have already looked at the Intel® Arria® 10 Core Fabric and General Purpose I/Os Handbook. Nothing about default values are mentioned.
Thanks in advance to all.
Rich
