13 years agoRandom results on FPGA
I'm using altera devices for about 10 years with quartus or quartus + synplify pro. I'm currently struggling for about a month !!! on this issue: Using the same netlist from synplify pro, the same timing constraints, and doing the place and route with quartus, I can get total different results on FPGA (stratix III): fully working, or failing on first HW accesses. The IP in the FPGA uses a lot of clock gating and I think that Quartus is not doing a good timing analysis (timequest reports no timing violations and the design is fully constrained), leading to such random results. Did you ever face such problem at your place ? Metastability report in timequest reports no problem. Resets are ok. Cooling the FPGA does not change anything. I never faced such situation before. I need help ! Alex32 Replies
rtl compiler from cadence behaves the same
Glad to hear that :)
