13 years agoRandom results on FPGA
Hello, I'm using altera devices for about 10 years with quartus or quartus + synplify pro. I'm currently struggling for about a month !!! on this issue: Using the same netlist from synplify...
13 years agoHow about if you heat the chip up in an oven or use freezer spray on it? Does that make problems appear and/or go away?
Is the clock gating/clock divider done by generating logic clocks (like using the MSB of a counter)?
