15 years agoquestion about VHDL library
Hi all, when I compile my VHDL design, there is always a error saying that * design library "book_lib" does not contain primary unit "utils_pkg"*. Does anyone know how to fix it?Thanks ...
15 years ago --- Quote Start --- library uses are usually ended with a semi-colon (;). --- Quote End --- Not necessary: you can write a comma separated list of things to use.
use ieee.NUMERIC_BIT.all, ieee.std_logic_1164.all; is the same as: use ieee.NUMERIC_BIT.all;
use ieee.std_logic_1164.all;
