13 years agoQuestion about the VHDL sequential statements
Hi, I just got some questions with the following processes when I design a simple MOD-9 counter for concept clarifications: 1. In program 1, the simulation result is actually counting from 0 ...
13 years agoAlthough you may see program 3 "working fine", it's not guaranteed to do. Depending on timing details, the counter may possibly count to 7 instead of 9. It's no correct synchronous description.
Program 1 is the correct counter code, but you need to understand the clearly specified behaviour of sequential processes. All signals are updated after the end of the process. the comparison "if q = 10" (no brackets required in VHDL, by the way) "sees" the previous counter value, not the new one. The below style emphasizes the actual operation of the code more clearly, I think.if q = 9 then
q <=0;
else
q <= q + 1;
end if;
