15 years agoquestion about IO status while power up for MAX II EPM1270
for MAX II EPM1270 For the weak pull-up resistor during power up,IO will show a high voltage(3.3V).I want to make IO show a low voltage by adding a pull-down resistor.what is the appropriate resis...
15 years agoPlease do not multipost your question.
The datasheet should give you the lowest possible value for the weak pull-up in the Max II. When you add a pull down you create a resistor divider, and depending on the voltage you want to reach (<0.8V for a TTL signal, as an example) it will give you the highest possible value for the pull down.
