8 years agoQuartus Prime Lite - Difficulties with simulation
Hi all, I am trying to figure out what I am doing wrong with simulations involving Altera IP.... Below is my incredibly simple design to show off the issue I am having. I pipe a clock into a PL...
8 years agoHi,
It's not related to license. 1.Use the msim_setup.tcl for simulation which help us to load all the necessary libraries. 2.And also follow the steps given in msim_setup.tcl which will eliminate the warning. The image which i have attached previously,There i tried to loaded the libraries manually which generated the warning. Now i have simulated the same project using script which eliminated the warning. So this warning may be related to libraries and compilation order. Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) https://www.alteraforum.com/forum/attachment.php?attachmentid=14839
